One leg of the digital pot needed to be tied to +5 and the other end floating. Rev 1 of the PCB connected the leg to ground instead. I was able to rework the current board to correct the but put a lot of heat into the chip getting the enamel wire soldered. Doesn't seem like they are covering full range of resistance any more....
Also added a jumper to allow Atari to power the ESP32 dev board. So far I've been powering with separate USB power supply.
Rev 2 PCB board order was placed last night.
