After a quick mini project to make a 3d printed back shell for the joystick connector, wired up a Revision 2 PCB with extra interface for the i2c level shifting. An extra strip board pcb was created with 2n7000 level shifters. The PCB 3.3V rail was hooked up to 5V making the whole PCB work at 5V. Not very pretty but everything worked when tested with 800XL and Pac-Man / Super Breakout.
