First thing first
Here the first analysis of the serial communication between the SPX-WFG01 and the A/C catch with 2 serial adaptators connected to my laptop.
The communication consist of ;
- A paquet sent by the gateway containing 15 lines starting with MT, where P is the adress.
- The response from the gateway containing 15 lines starting all with OK and where P is the containt at this adress.
My assumption is that the last line (adress 0900) contains the A/C serial n° (hidden)
in addition :
- - Carriage return is 0x0D 0x00
- - C is simply = P XOR 0xFF
Now start playing ...
I connect my smartphone to the Hi-humo app and try to catch some commands between
In this case a very diffrent paquet is sent to the A/C containing 12 lines staring all with ST, P contains the adress followed by the value.
If everything works well the A/C should asnwer
One setp further !
I made some additionnal test with the IR remote control. Of course since the receiver is located directly inside the A/C housing the communication will not pass through the SPX-WFG01 and I'll not be able to get the content.
But the good news is that the the A/C continues to send the ACK on his serial port so I was able to made some interesting comparisons.
... stay tuned !
