I choose finaly to communication with HomeAssistant via the MQTT integration.
MQTT is extremely light and reliable for this purpose.
I'll add also a custom thermostat-card. I'll show you this late...
Here me MQTT communication protocol :
I also add a frequently a STATE information in JSON format
device_7/STATE :
{"power":"OFF","op_mode":"off","swing_mode":"off","fan_speed":"auto","temperature":21,"room_temp":22,"RSSI":-55}
and a MQTT last will message to be able to check if the device is on or offline.
device_7/LWT : Online
