I helped a friend build a tree, and at his request added a simpler web UI for kids and spouses. :) It only allows turning the tree on and off, choosing a solid color or pattern. The source is on GitHub: https://github.com/evilgeniuslabs/tree-v2
A project log for Wi-Fi RGB LED Christmas Tree
6.5' white tree with 250 WS2811 RGB LEDs, driven by an ESP8266 microcontroller using the FastLED library, controlled with a web app and IR.
