Hackaday.io Hackaday.io
Sign up Log in
µ-Sonum
A VST to experiment with granular synthesis
matteo-amerenaMatteo Amerena
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
140
0
0
0
Team (1)
  • matteo-amerenaMatteo Amerena
Join this project's team
  • Github
completed project
This project was created on 05/18/2021 and last updated 5 years ago.
Description
The application is built in C++ using the JUCE framework and an Hilbert transform implementation.
The goal is to provide a useful and relatively simple tool to play with granular synthesis and understand it better, along with easily experiencing independent time-stretching and frequency shifting.
Details
Log In/Sign up to comment
Sign up with Github
OR
From 28-st of January 2016 till 8-th of February 2016 anyone can try SelfieBot.
Project Owner Contributor
Endurance SelfieBot demo starts! Hurry up!!!
georgefomitchefgeorgefomitchef
Sound spectrogram frequency resolution can be enhanced by using phase changes between FFT slices.
More frequency resolution from a spectrogram.
bruce-landBruce Land
Home grown bio-piezoelectrics and modular synths for fun and profit
Screaming Mushrooms
fizzy-wizardFizzy wizard
A tool made in 15 minutes that will help you cut perfect V-Groove in polystyrene foam. The groove will help bend the foam.
Cheap-dirty-perfect V-Groove Foam Cutter / Bender
ftreganftregan
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "µ-Sonum", please tell us the reason.
Send message
Remove Member
