Low cost Augmented Reality VR for microcontroller
Optimized for use microcontrollers and SPI displays
popular ST7789 1.3" IPS 240x240
FEEL LIKE IRON MAN !!!!!
Something like Iron man helmet but can drive with simple arduino
Raspberry pi zero, PICO and more
- Driven with simple SPI interface
- Helmet cost about 30$ displays 10$
- 2x SPI IPS display 240x240 ST7789
- Easy drive with #samd21 #rp2040 #raspberrypi #ESP32
- no complicated HDMI
- beautiful and clear image in all you view
- LOW power about 60mA including SAMD21 MCU
- parallel or separated (for 3D) display driving
- USB OTG
YOU CAN TYPE ON KEYBOARD AND DIRECT READ MESSAGES :D
-module also have prepared LoRa radio for sending/receiving messages and GPS
TODO:
- Adjustable distance between displays (flex cable or solder bridge)
- Test on Raspbery pi zero
- select nice 8pin cable/connector etc. USB-C with custom pinout
How it wear:
Against google glasses little bigger :D
Entry video:
First version driven with Armabrain SAMD21 core, this version works standalone with USB-OTG keyboard
and long range radio LoRa for sending/receiving messages
new version with raw displays only
ZEPIR LCD.zip
Raspberry Pi universal SPI display hat with AUDIO amplifier
x-zip-compressed - 310.95 kB - 04/19/2022 at 20:22
Download
AR-LCDONLY2.brd
brd - 51.45 kB - 06/12/2021 at 21:23
Download
AR-LCDONLY2.sch
sch - 146.20 kB - 06/12/2021 at 21:23
Download
glass2.zip
Production gerbers
x-zip-compressed - 55.55 kB - 06/12/2021 at 21:23
Download
View all 5 project logs
Roko Mocca wrote 05/29/2021 at 19:39 • point
I am really curious where can i find the helmet part
bobricius wrote 06/07/2021 at 21:11 • point
Etc this https://www.aliexpress.com/item/1005001590454754.html
robomaniac wrote 05/27/2021 at 15:50 • point
do they work in bright sunlight? can you read it correctly out side?
bobricius wrote 05/28/2021 at 19:49 • point
I will test
wngg0023 wrote 09/14/2021 at 07:20 • point
Hello sir have you tested it under sunlight? How did it go?
Dan Maloney wrote 05/20/2021 at 22:04 • point
Very cool, those glasses were a great find. Next step: gaze detection so you can do data entry.
