Hi everyone. Welcome to the project blog!
As I mentioned in the project description, this project is an evolution from my earlier project "WiFi Rocks". I though I'd give it another go and blog my progress.
Back then, I had purchased a little WiFi Linux board to put in the solar-powered rock. The power consumption of this device would have flattened the battery in the rock in no time at all. Given the prevalence of ESP8266 and ESP32 boards around now and their ability to use protocols like MQTT to upload data to the internet, I thought I'd base this new project on these devices.
This time round, I'm not limiting myself to a solar powered rock! I'm going to base it on something I could buy at my local Bunnings store here in Australia. It's a big hardware chain. Kind of like Home Depot in USA. Most of the solar powered things are garden lights of some description. Path lights. Motion sensor floodlights. Regular floodlights. Spotlights. You get the idea. Now many have pretty small solar panels, so I'm looking at something that's a bit bigger. I haven't really planned the high-level requirements yet. Basically I want to be able to use a standard size Li-ion battery for power storage. Could be 18650. Could be 14500. Could be 16340. I've then got the option then to buy a larger capacity battery than the light comes with.
I went there today and ended up with a couple of lights. First one is this one. The "Arlec 30 Lumens LED Garden Spot Solar Light". It's only IP44, so not waterproof. But it should withstand showers. Plus, I can always add some "waterproofing" later (silicon sealant). The reason I got this one is because it has a few nice features:
- There's a 18650 battery under the solar panel. Granted it's a puny 1000mAh one, but it'll get an upgrade later.
- The LED housing is made of aluminium. Might be good for transferring heat out (and in).
- It has a flat back that can be used to mount other accessories like an antenna (more on this later)
- The solar panel itself looks like its higher voltage than many of the other solar lamps.
So what do I mean by "looks" like it's higher voltage? Lets go back to some solar basics.
Most of these solar lights use polycrystalline silicon solar cells. A single silicon solar cell will output approximately 0.5V. Some higher efficiency cells output a little more, but 0.5v is a close enough approximation. Now, to charge a battery, we need a voltage slightly above the voltage of the fully charged battery. This can be done a couple of ways. We could boost the voltage of the single solar cell using a boost converter. There are some energy harvesting ICs that will startup at this low voltage. But there are losses involved with boosting from such a low starting point and the system could be more efficient by having a higher input voltage. This can be done by putting the solar cells in series. So depending on the output voltage you need, you just put more cells in the string. Now alot of the smaller garden lights use a single 1.25v NiCad AAA battery for energy storage. To reach or exceed that voltage, multiple silicon cells in series are required. These garden lights often use a single chip "Joule Thief" chip, like YX8018 to drive the single LED once the sun goes down and charge the battery during the day. There's plenty of articles online to describe this process. HERE's one from Analog Devices. It describes a mini 3x3cm solar panel that outputs 2.7V in full sunlight. This would be around 5 cells in series. The little epoxy encased solar panels are actually made up of small pieces of silicon cells soldered together to make the higher voltage string. Embedding the cells in epoxy keeps them together and protected from the elements.
Back to the solar panel on the Arlec Spotlight. I noticed that this panel had 11 cells joined together. So without any real-world testing, I figured that this panel would output at least 5.5v, and probably closer to 6v. This is well above the 4.1 or 4.2v of the 18650 battery that this light contained. The cell measures 75x60mm. It's not huge, but a quick internet search resulted in an identically sized one that outputs around 0.6W, although the panel I found was 3V and only had 6 cells in series, but the power density would be similar.
After watching the video from Andreas Spiess that talked about the kinds of li-ion charges available from AliExpress, I figured that if I didn't use the charging circuitry that the light already contains, because it was probably going to be some minimal cost Joule Thief circuit, I could use a charger and power supply based on the TP4056, just like in the video. I ordered one of these chargers so I can replicate the design shown in the videos.
Another thing that has motivated me to make this project is the TinyGS project. This is a tiny ground station that receives radio transmissions from satellites in space. It's based on a variety of ESP32 modules that have a UHF transceiver on the same board. These are available from Aliexpress and other vendors online. For under $50, you can build a satellite ground station!!! My station uses a TTGO LoRa32 V2 module. It's currently just powered by a USB 5V adapter. I'd like to make it solar powered so that I can locate it further away from the house and not need a longer cable to power it. The aluminium housing of the Arlec spotlight has a nice flat surface where I can mount connectors or antenna sockets. Plus, the solar panel on the Arlec might juuuuuust be big enough to power the GS during the day. I'll do some measurements of everything soon to try and see if it's feasible!
Stay Tuned.
