The software is now downloadable from this page, if you'd like to give it a try.
I attached some example files to help you decide whether you need this app or not.
You can visualize the G-code files using: https://ncviewer.com
A software written in Python than detect contours on images and converts them to SVG or creates G-code for 3D printers
imageToGcode.zipx-zip-compressed - 13.02 kB - 05/03/2022 at 21:15 |
among-us-original-image.pngThis is the original image I used to demonstrate the software. Source and creator of this picture: https://pixabay.com/users/foxpool-19974991/?utm_source=link-attribution&utm_medium=referral&utm_campaign=image&utm_content=6008615Portable Network Graphics (PNG) - 179.87 kB - 05/23/2021 at 14:10 |
among-us-3-layers-gcode.gcode3 layer G-code generated with a 3 mm height decrease between layers,gcode - 295.51 kB - 05/23/2021 at 14:08 |
among-us-1-layer-gcode.gcodeSingle layer G-code, this is the one you can see on drawing made by my 3D printer.gcode - 98.68 kB - 05/23/2021 at 14:08 |
among-us-svg.svgThe created SVG from the original image.svg+xml - 26.28 kB - 05/23/2021 at 14:08 |
