OPL3LPT : OPL3 FM synthesis sound on parallel port
Parallel port sound card, successor to OPL2LPT, uses OPL3 FM synth chip
This card is the successor to the OPL2LPT.
It uses the yamaha OPL3 (YM262+YAC512) chipset, and features a stereo headphone amplifier.
It is backward compatible with OPL2LPT, and now has wide DOS software support.
pcb available here : https://www.serdashop.com/OPL3LPT
this card is the successor to the OPL2LPT.
It is backward compatible with OPL2LPT, so the following software works with OPL3LPT :
DOS game compatibility using the 'adlipt' project : download executables here : https://github.com/pdewacht/adlipt/releases/latest
Get started quickly playing DOS games, using the DOS GAME Demo Pack
A special version of adlib tracker, that supports OPL3LPT, can be found here :  https://github.com/pdewacht/at2lpt/releases
review by Retro Erik, using opl3lpt on a 286 12mhz
View all 3 project logs
