After a long time without any news lot of things was done in background and mainly by Balda & Nico which are amazing contributors to HydraFW !
New features planned for HydraFW v0.6 release:
- HydraBus specific:
- JTAG protocol mode (thanks to Baldanos)
- Classic JTAG (TDI/TDO/TMS/TCK)
- Can be used with command line
- BusPirate-compatible OpenOCD binary mode (openocd command)
- Can scan a JTAG bus with IDCODE and BYPASS methods (idcode and bypass commands)
- Can try to find JTAG bus on all GPIOB pins (like JTAGulator) (brute command)
- Logic Analyzer mode new command sump up to 1MHz 16chan with SUMP support (thanks to Baldanos)
- Compatible with ols-0.9.7.2 see http://ols.lxtreme.nl see also ols profile for hydrabus https://github.com/bvernoux/hydrafw/blob/master/ols.profile-hydrabus.cfg
- Compatible with sigrok: sigrok-cli & PulseView see http://sigrok.org
- UART:
- Raw mode sniffer added see command bridge in uart mode (thanks to Baldanos)
- Fix bug in baudrate->BRR for very high speed > 4Mbits/s (thanks to doegox)
- HydraNFC specific:
- NFC Sniffer (ISO14443A/MIFARE) command for Wireshark with specific dissector (thanks to NicoHub)
- To be released see https://github.com/NicoHub/Wireshark-RFID-dissector for more details
- Sniffer new command sniff-dbg with following new features:
- Add after each 8bits/byte the parity (ASCII char “0” or “1” + space), End Of Frame Timestamp + RSSI
- Tag Emulation Beta:
- Mifare Emulation (Anticol+UID+HALT) see new command emul-mifare
- ISO14443A Emulation (TRF7970A hardware Anticol/UID) see new command emul-3a
- Tag Read:
- scan command now support 4 and 7bytes UID for ISO14443A (thanks to NicoHub)
For more details see https://github.com/bvernoux/hydrafw/wiki/Task-List
