07.09.2020 - HydraFW v0.10
This version is the first stable version (if you find any issue please create an issue).
Big thanks to Baldanos to be the lead developer on HydraFW since 2015 including all major contributions of the project (191 commits, 545776 lines added and 479088 lines removed)
Generic:
- Update ST drivers to 1.7.8 (Based on STM32CubeF4 Firmware Package V1.25.x / 12-February-2020)
- Update ChibiOS 18.2.0 (git version)
- Plug & Play USB Serial Driver using standard driver for windows 8.1 & 10 (Thanks to Guigz2000)
HydraBus specific:
Console syntax improvements (Thanks to Azox)
- Support Compressed mode
- Add error message when invalid token found with position highlighted
- Various fixes for BP compatibility + TL_TOKEN_DELIMITER issue
- For more details see https://github.com/hydrabus/tokenline/commits/master
- Smart Card (Big thanks to the contributors sylvainpelissier/Azox)
- ADC trigger
- SWD bruteforce (2-wire mode)
- See also HydraFW OpenOCD guide
- JTAG bruteforce fixes and improvements
- Auxiliary pin
- I2C for non intrusive sniffer for SDA line
- Display improvement for delays (microseconds) (Thanks to Azox)
- Auxiliary pin
- Flashrom support using native Serprog mode (see https://github.com/hydrabus/hydrafw/wiki/HydraFW-SPI-guide#flashrom-usage for more details)
- Supported with any version of Flashrom since v0.9.8 or more (tested with success also with latest Flashrom v1.2)
HydraNFC Shield v1 specific:
- Binary NFC Reader mode (Thanks to gvinet)
- pcap file format support for sniffer output (Thanks to AAsyunkin-se)
- HydraNFC Shield v1 is now superseded by HydraNFC Shield v2 in an other fork see https://github.com/hydrabus/hydrafw_hydranfc_shield_v2
Contrib / script / documentation
- pyHydrabus Python bindings (Thanks to Gheko for helping on this)
- Script to dump SPI flash
- Script for 93c46 EEPROM read/write/erase
- HydraBus/HydraFW wiki updates
- Build/Debug on Windows/Linux with STM32CubeIDE using SWD and SWO traces
Benjamin Vernoux
