29.11.2015 – HydraFW v0.6 Beta
Generic:- Update of tokenline, now both
T_ARG_INT
andT_ARG_FLOAT
take k, m and g suffixes and apply a decimal factor on both argument types. It is always compatible with old syntax khz, mhz, ghz (only first character is checked).
- Added 2-wire mode (support frequency up to 1MHz) (thanks to Baldanos)
- Added random command new token ~ (
T_TILDE
) to write random byte (thanks to Baldanos)- Random number generator (using STM32 hardware RNG) returns a 32bit random number in hex (thanks to Baldanos)
- Added jtag scanner/debugger mode (thanks to Baldanos)
- Classic JTAG (TDI/TDO/TMS/TCK)
- Can be used with command line
- BusPirate-compatible OpenOCD binary mode (openocd command)
- Can scan a JTAG bus with IDCODE and BYPASS methods (idcode and bypass commands)
- Can try to find JTAG bus on all GPIOB pins (like JTAGulator) (brute command)
- Added sump mode, Logic Analyzer up to 1MHz 16chan with SUMP support (thanks to Baldanos)
- Compatible with ols-0.9.7.2 see also ols profile for hydrabus
- Compatible with sigrok: sigrok-cli & PulseView
- Added can mode (thanks to Baldanos & smillier)
- Needs a dedicated shield like HydraOBD to communicate with a real CAN bus
- Support CAN bus 1 or 2 (speed up to 2M)
- Support read, read continuous, write, id and filter commands
- Added in uart mode the bridge command to be used as UART Raw sniffer (thanks to Baldanos)
- UART: fix bug in baudrate->BRR (thanks to doegox)
- HydraNFC Tag Emulation UID Mifare 1K & ISO14443A
- Mifare Emulation (Anticol+UID+HALT) see new command emul-mifare
- ISO14443A Emulation (TRF7970A hardware Anticol/UID) see new command emul-3a
- Rename command mifare to typea (ISO14443A) as it was not specific to MIFARE
- scan command now support 4 and 7bytes UID (thanks to NicoHub)
- Sniffer new command sniff-dbg with following new features:
- Add after each 8bits/byte the parity (ASCII char “0” or “1” + space)
- End Of Frame Timestamp + RSSI
See all commands here: https://github.com/bvernoux/hydrafw/wiki/HydraFW-commands
HydraFW Link: https://github.com/bvernoux/hydrafw
Release with pre-built firmware: https://github.com/bvernoux/hydrafw/releases/tag/v0.6-beta
