16.04.2016 HydraBus HydraFW v0.7 Beta released (github)
Generic:- Fixed ultra slow build (because of built in rules…) thanks to tuxscreen post http://hydrabus.com/forums/topic/make-is-ultra-slow/#post-696 for the fix
- Updated ‘tokenline’ submodule to the latest version
- Change T_ARG_INT to T_ARG_UINT, supporting only unsigned integers.
- Added freeform string as byte sequence (in addition to freeform integers) (thanks to Baldanos)
- Added Binary Modes full documentation in wiki
- Added Binary Modes (USB CDC compatible with BusPirate BBIO/Bitbang) with:
- CAN (thanks to Baldanos)
- Corrected filters handling. Now works for both CAN interfaces
- Fixed
bsp_can_rxne()
- Fixed error in can2 pin description
- Added speed change for CAN
- Optimized sump critical part and Lock Kernel during get_samples()
- JTAG scanner/debugger mode like JTAGulator (thanks to Baldanos)
- Add support for TRST
- Add support for MSB/LSB when reading
- Added in standalone mode sniffing LED indication #36 LED 2 ON for Standalone mode
- Fixed IRQ bug (stopped when enter/exit from sniffer or emul mode)
- Fixed Trf797xInitialSettings with workaround of Errata SLOZ011A–February 2014–Revised April 2015
- HydraNFC emulation commands are in alpha stage and they will be fixed in next version of HydraFW
- Added in emul-mifare display of UID parameter when started
- Added in emul-mifare 4 bytes UID parameter
- Added emul-mf-ul command for Mifare Ultralight Emulation preliminary/work in progress code
- Added dm0 command => Direct Mode 0 Sniffer Test work fine mainly for test with a Logic Analyzer on PC2
- Added dm1 command => Direct Mode 1 Test (Work in Progress to test TX SDM & RX DM1)
