Finally I found why I was problems with crystal before and then I was opting for external clock
Now I'm going to eliminate external clock and I'm going to use 4MHz maintain 48MHz.
changes again... xD
I know crystal must be near of MCU but even so I still had problems too.
Also I'm going to add an actuator enable/disable switch
SLAVE:
MASTER:
SLAVE ACTUATOR (STEPPER MOTOR):
