Bluepill based CPU. Tried to keep the wiring and soldering minimal, I think it was a good result!
The board is powered from the LED strip connector, and the 7 pin header is for the buttons. As that side of the board has 2 ground pins and a 3V3, I used for pulling up/down the input buttons.
