Not much is happening, I'm still not working on the gait, but in the mean time the switches for the legs arrived, so I assembled a few:
![](https://cdn.hackaday.io/images/2912931642078531969.jpg)
I'm also at version 5 of the PCB now, with all the spacing problems mentioned previously fixed, and a piezo speaker added back. Seems the problem with the ribbon cable connectors can be solved by inserting the cables from the top instead of the bottom of the plug.
