With the robot mechanically pretty much good enough, the next steps are of course programming and documenting. The latter will require some drawings, so I sat down with OpenSCAD to make a simplified model of the robot, so that I can use it for assembly instructions. Here's a simple animation of the "exploded" view:
deʃhipu
