The screen won't work with 5 Volts out of the box, so it needs to be modified a litlle.
For that I soldered a wire to the power line and the 2nd pin of the power regulator IC and that does the trick:
I then soldered on wires to test it out to the corresponding pins:
And it works!
sotasystems
