We've modelled the camera stand in CAD (see files section for STEP file), so it is easier to build for you.
![](https://cdn.hackaday.io/images/9037431623674563607.jpg)
We will add build instructions as well. [Update: Build instructions are available in the Instructions Section now]
Here are some detail shots for the meantime:
![](https://cdn.hackaday.io/images/4805111623674969268.jpeg)
![](https://cdn.hackaday.io/images/2741151623674975732.jpeg)
![](https://cdn.hackaday.io/images/1044331623674982203.jpeg)
![](https://cdn.hackaday.io/images/401321623674989925.jpeg)
![](https://cdn.hackaday.io/images/3722961623674996248.jpeg)
![](https://cdn.hackaday.io/images/3128401623675003416.jpeg)
![](https://cdn.hackaday.io/images/3749841623675010256.jpeg)
