This project aims at designing the flight computer for a small scale quad-copter. I would like to look into using cameras for obstacle detection to allow for autonomous avoidance and possibly mapping.
Some general goals of the project:
- Learn how to use STM32 microprocessors
- Learn how to fly a quad-copter
- Learn how to design control systems for fly-by-wire and eventually autonomous control
- Learn how to design PCBs that use FPGAs
- Learn how to process camera data, particularly to combine data from multiple cameras for depth measurements
- Make some cool renders in blender along the way
These goals are quite general, but it comes down to a number of steps:
- Design a flight computer and build a quad-copter capable of being controlled via fly-by-wire
- Design a camera board with an FPGA and connectors commonly used camera modules
- Design a Dedicated dual camera obstacle detection sensor board
- Build the final quadcopter making use of the flight computer (possibly requiring an updated version) and multiple obstacle detection boards facing in each direction
There are a number of extra steps that are probably going to be required. Firstly, that I should learn to fly a small quad-copter (probably one of the FPV ones). There may also need to be several iterations of the electronics, so I'll just have to see how it goes.
Current status:
| Component | Design Status | Build Status | Testing Status | Notes |
| Flight computer | v1.0 Completed | v1.0 In progress | v1.0 not started | 3V3 shorted to ground |
| Air frame | v1.0 Completed | v1.0 In progress | v1.0 not started | |
| Fly-by-wire flight software | v1.0 not started | v1.0 not started | v1.0 not started |
Charlie Smith
Giovanni Durso
