DIY ESP32 SmartClock Kit with Weather Forecasting
An interesting kit for soldering and assembly
This is a soldering kit for the starters to learn soldering. After 1~2 hours soldering and assembly, and easy steps to set the Wifi name/password with a phone, you will get:
1. An real-time clock, it will get the world real-time from the Network timing protocol, you can set your local time zone easily
2. An Alarm clock, with loud noise
3. An Online world weather forecaster, about the local temperature/weather, you can easily change/alter your address/cities without any re-programming
Schematic V1.1.pdf
Adobe Portable Document Format - 812.04 kB - 05/28/2021 at 06:35
Preview
  • Charge
    Makerfabs06/08/2021 at 09:25 0 comments
    The board Integrated with the chargeable chip MCP73831. MCP73831 is a highly advanced linear charge management controller for use in space-limited, cost-sensitive applications. The max charge current is 500 mA. The schematic of the charge part on the board is shown as the picture. Plug the USB cable to charge the battery. When charging, the charge LED is light, and it will turn off when fully charged.
View project log
  • 1
    How to set the ESP32 WIFI without re-programming, with a phone.
    Here is the way of how to set the ESP32 Wifi, without reflash the ESP32 code.., so the users can directly make the smartclock with the local Wifi:
View all instructions
Rich text editor
