The board Integrated with the chargeable chip MCP73831. MCP73831 is a highly advanced linear charge management controller for use in space-limited, cost-sensitive applications. The max charge current is 500 mA. The schematic of the charge part on the board is shown as the picture. Plug the USB cable to charge the battery. When charging, the charge LED is light, and it will turn off when fully charged.
