One "fun" thing I learned while soldering all the wires is that these motors are incredibly heat sensitive. If you hold the soldering iron on the motor leads for more than a fraction of a second, you'll fry the motor. You'll know it's dead because the axle will be completely locked up and won't rotate. Thankfully, I only did this to 3 or so motors, and I had 5 extra spare motors. 😬
Next version I'll see about making a PCB that I can directly solder the motors to. Then I can have a smaller number of ribbon cables coming off the board. So far soldering has the been the biggest pain of this project.
