Front Panel Features
- 50 pin connector
- 2x25 Pinout matches RETRO-EP4CE15 Card pins (1:1 cable)
- Some unused pins - wired to +3.3V/GND for connecting other cards
- 12 Value LEDs (DB0-11) - octal format
- Display options: Program Counter (PC), Memory Address, Memory Data, Accumulator
- 12 Load Value Slide Switches (SL0-11) - octal format
- Enter values: PC, Memory Address, Memory Data, Accumulator
- LNK - Link value slide switch
- DISP - Display 12 Value LEDs select pushbutton
- Cycles between LEDs displaying PC, Memory Address, Memory Data, Accumulator
- Pushbutton Switches
- STEP pushbutton - Increment PC
- LDPC pushbutton - Load PC from Value Slide Switches
- DEP pushbutton - Store value from Value Slide Switches to memory
- LDA pushbutton - Store value from Value Slide Switches to Accumulator
- RES - Reset pushbutton - Resets CPU
- PB1 - spare pushbutton - Used as EXAMINE
- 4 DISP LEDs - Cycle between 12 LEDs source with DISP pushbutton
- PC - 12 LEDs display Program Counter value
- MADR - 12 LEDs display Memory Address value
- MD - 12 LEDs display Memory Data value
- AC - 12 LEDs display Accumulator value
- LINK LED - Displays Link value
- RUN LED - Running program
- RUN/HALT slide switch
- PWR - Power LED
- 95x95mm form factor
- (4) 6-32 mounting holes
