Fresh Boot
- USB cable disconnected (FPGA card is off).
- Run/Halt on Front Panel set to HALT (down position).
- Set Address switches on Front Panel to 0023.
- Plug in USB cable to PC.
- PC LED on Front Panel should display next address (0024).
- Run PuTTY on PC.
- Serial port found in device Manager.
- Serial port set to 9600,SPACE,7,1 (may not be optimal but it worked).
- Turn on RUN switch on Front Panel.
- Press RES button on Front Panel.
- Prompt comes up in Serial terminal (PuTTY).
Reboot
The Internal SRAM needs to reloaded.
- Run/Halt on Front Panel to HALT (down position).
- Hit load switch on FPGA card (SW3).
Alternate Re-boot
From the OS8 Handbook. Boots to command line.
- Set Run/Halt to HALT
- Set switches to 7600
- Press RES (Reset)
- Press LDPC (Load PC)
- Press RES (Reset)
- Set Run/Halt to RUN
- Press RES
Files on the RK08 (SD Card)
- DIR /A
ABSLDR.SV 6 FLOP2 .BI 2 RALF .SV 19 ADVENT.DC 9 FORLIB.RL 170 REMEM .SV 5 ADVENT.FT 11 FOTP .SV 8 RESORC.SV 14 ADVENT.IN 1 FRTS .SV 26 RKBOOT.SV 2 ADVENT.LD 145 FUGUE .MU 42 RKCOPY.SV 11 ADVENT.RL 4 FUTIL .SV 27 RKFRMT.SV 9 ADVENT.TX 201 F4 .SV 20 RKUTIL.SV 15 AINDX .DA 50 GETIN .FT 6 RLFRMT.SV 7 AMAIN .RA 270 GETIN .RL 4 RL2FMT.SV 8 AMAIN .RL 50 GETWRD.RA 16 RND .FT 1 ATEXT .DA 144 GETWRD.RL 2 RND .RL 2 A5TOA1.RA 6 HEADER.SV 14 RSPEAK.RA 3 A5TOA1.RL 3 HELP .HL 102 RSPEAK.RL 2 BASIC .AF 4 HELP .SV 8 RSTRGM.FT 13 BASIC .BA 11 INIT .TX 1 RSTRGM.RL 8 BASIC .FF 4 INITAD.FT 65 RTFLOP.SV 15 BASIC .OV 16 INITAD.RL 23 RUNAD .BI 1 BASIC .SF 4 INUSE .TE 8 RXCOPY.SV 9 BASIC .SV 11 IO .FT 2 RXFIX .SV 3 BASIC .UF 2 IO .RL 2 RXREAD.SV 7 BASIC .WS 1 JUGGLE.RA 3 SAVEGM.FT 13 BATCH .SV 10 JUGGLE.RL 2 SAVEGM.RL 8 BCOMP .SV 17 KL8E .PA 53 SD .BN 1 BITMAP.SV 5 K12DEB.SV 4 SD .LS 28 BITSET.RA 11 K12DEC.SV 5 SD .PA 11 BITSET.RL 3 K12DJG.SV 33 SEED .RA 7 BLOAD .SV 8 K12ENB.SV 4 SEED .RL 2 BLOCKS.SV 8 K12ENC.SV 6 SET .SV 20 BOOK .BI 1 K12MIT.SV 33 SPACWR.BA 39 BOOT .SV 5 LAYOUT.TX 4 SPEAK .RA 28 BRTS .SV 15 LCSYS .BI 3 SPEAK .RL 4 BUG .FT 3 LOAD .BI 1 SRCCOM.SV 5 BUG .RL 2 LOAD .LS 8 SVDUMP.SV 4 BUILD .SV 37 LOAD .SV 16 TDCOPY.SV 7 CAMP .SV 13 LPTSPL.SV 10 TDFRMT.SV 9 CARRY .RA 5 MCPIP .SV 13 TECKBM.TE 2 CARRY .RL 2 MOVE .RA 4 TECO .IN 1 CCL .SV 31 MOVE .RL 2 TECO .SV 32 CHESS .SV 15 MSBAT .SV 23 TECO .TE 1 COMPAF.SV 5 MUSIC .SV 9 UCSYS .BI 3 COMPIL.BI 2 PAL8 .SV 19 USR .RA 46 CONVRT.SV 5 PARAM .SV 12 USR .RL 4 CREF .SV 13 PASS2 .SV 20 VOCAB .RA 7 DECX8 .SV 43 PASS2O.SV 5 VOCAB .RL 3 DIRECT.SV 7 PASS3 .SV 8 VTEDIT.TE 8 DOUGTE.ST 1 PCT .RA 2 WILD .BI 1 DROP .RA 4 PCT .RL 2 WILD .DI 5 DROP .RL 2 PIP .SV 11 WILD .TE 2 DSTROY.RA 1 PIP10 .SV 17 WILD .TM 1 DSTROY.RL 2 PSPEAK.RA 5 WPFLOP.SV 14 DTCOPY.SV 5 PSPEAK.RL 2 YES .FT 2 DTFRMT.SV 7 PUT .RA 3 YES .RL 3 EDIT .SV 10 PUT .RL 2 2000 .TX 1 EPIC .SV 14 QUIT .SV 2 31 .76 1 FLOP .HN 3
Resources
.R RESORC */E 163 FILES IN 2639 BLOCKS USING 5 SEGMENTS 553 FREE BLOCKS (7 EMPTIES) # NAME TYPE MODE SIZ BLK KIND U V ENT USER 01 SYS RK8E RWF 3248 SYS 0 F 07 02 DSK RK8E RWF 3248 SYS 0 F 07 03 BAT BAT R 16 B 00 04 TTY TTY RW 17+ KL8E E 176 05 RKA0 RK8E RWF 3248 20 RK05 0 A 20 06 RKB0 RK8E RWF 3248 20 RK05 0 A 21 07 RKA1 RK8E RWF 3248 20 RK05 1 A 22 10 RKB1 RK8E RWF 3248 20 RK05 1 A 23 11 RKA2 RK8E RWF 3248 20 RK05 2 A 24 12 RKB2 RK8E RWF 3248 20 RK05 2 A 25 13 RXA0 RX02 RWF 988 21+ 32 14 RXA1 RX02 RWF 988 21+ 36 15 B3 37 RWF 22+ 117 16 B4 37 RWF 22+ 113 FREE DEVICE SLOTS: 01, FREE BLOCK SLOTS: 03 OS/8 V3T
land-boards.com
