Now that the front end was in a satisfactory state, it was time to revisit the architecture of the digital interface. At this point it had been over a year since I designed that board. I chose a USB 3 Gen 1 interface capable of 400 MB/s (which proved to be 370 MB/s in practice) as a stopgap to develop on until a USB 3 Gen 2 chip was released that could match the 1 GB/s throughput of the raw ADC data. Unfortunately, the FX3G2 on Cypress's USB product roadmap failed to materialize, leaving me with few options.
I considered using the Cyclone 10 GX (which is the cheapest FPGA with the needed 10 Gb/s transceivers) with USB 3 Gen 2 IP, but even this couldn't reach 1 GB/s, topping out at 905 MB/s according to the vendor's product sheet. I considered PCIe, which is super common on FPGAs, with free IP and loads of vendor support! However, that would seem to limit this to desktops, since most people don't have PCIe slots on their laptops.
They did have the next best thing though! Thunderbolt 3 (and now USB 4 and Thunderbolt 4) supports up to four lanes of PCIe Gen 3 at a maximum throughput of 40 Gb/s. Perfect! Unfortunately, though the chips themselves are freely available on Mouser, the datasheets are not. I didn't worry about that yet, as I could prototype the system as if it was just a PCIe card by using an external GPU enclosure. This review and teardown really showcased how simple the extra Thunderbolt 3 circuitry was, so I didn't feel like it was a big stretch to incorporate it once the PCIe design was tried and true. I bought the enclosure and got to work finding a new FPGA to do all the PCIe magic.
![](https://cdn.hackaday.io/images/4179671632884460921.jpg)
I used this list of FPGA development boards to find the most affordable way to start prototyping with PCIe. This turned out to be the Litefury, an Artix-7 development board which appears to be a rebadged SQRL Acorn CLE-215+ (an FPGA cryptomining board). Although this board had the four lanes of PCIe I needed, it came in an M.2 form factor so it needed an adaptor. It didn't have a built in programmer either, so I used this one, which was the cheapest one that worked directly with Vivado (Xilinx's IDE for their FPGAs).
Shown above is the Vivado block diagram of the Litefury example design, this design allows DMA access from the PC to the onboard DDR3 memory and vice verse. I would use this to verify the transfer speeds when connected directly to a desktop PC compared to those through Thunderbolt when it was installed in the enclosure. I installed the XDMA drivers (which I had to enable test mode in Windows for, since the driver is unsigned) and ran a basic transfer with the maximum transfer size of 8 MB.
It took 7.072 milliseconds to receive 8 MB, which is just over 1.1 GB/s! Best of all, this number didn't budge when I tested it over Thunderbolt!
This inspired me to finally gave this project it's name: ThunderScope!
Follow this project to catch my next post on designing a 1 GHz PLL to take advantage of this blazing fast transfer rate, and then promptly learning my lesson about cribbing off the other oscilloscope manufacturers!
Thanks for giving this post a read, and feel free to write a comment if anything was unclear or explained poorly, so I can edit and improve the post to make things clearer!
