In an effort to save costs for EBike batteries, we created a battery system that utilizes 40V RYOBI power tool batteries to power an EBike. We used a combination of 3D printed and COTS parts to make the mounts and wiring harnesses. Our system involves two batteries, connected to the motor in parallel via a Y-harness. Each battery is mounted to the bike on the mounts we designed, and an internal wire harness routes power to the Y-harness.
The GITHUB documentation MENTIONS the BOM, but does not provide it. I'm interested in finding out how to obtain the motor, and then I can either try to install myself or, as the notes suggest, go to a bike shop to help in the installation.
I can do the 3D printing of the battery mounts and also the wiring.
Assuming I can get the project working I could add power monitoring/logging to measure performance and maybe crowdsource results with other makers.
A very nice project. I just wish batteries here in Sweden were cheap enough to utilize this way. Had a look online and 2 of those batteries would cost roughly 3600sek which is in the same region as a cheap e-bike battery of >10Ah. What happens when 2 batteries are inserted if they have uneven charge/voltage? Does the internal BMS:es even the voltages out safely, or is there an unsafe "fast charge" of the battery with lower voltage?
Where's the BOM? Specifically, the motor?
Charlie in Houston, TX
