Designed a custom I/O processor (IOP) in VHDL. Runs autonomously from the Host CPU.
8 Bit CPU Application
The 32 LEDs can be used to monitor
- 16-bits of instructions
- 8 - bits of data
- 8 status lines (Run, etc)
The 32 pushbuttons can be used for:
- 16-bits of address
- 8-bits of data
- 8 control lines (Run/Halt, Examine, Deposit, etc)
IO Processor (IOP) Block Diagram
IOP Features
- 16-bit instruction
- 4-bit opcode
- 4-bit register select
- 8-bit address/offset
- I/O Memory Interface
- 8-bits of data (in/out)
- 8 address lines
- Read/Write strobe
- 3 bit grey coded state counter running at 50 MHz
- 50 MHz/8-bits/instruction = 6.25 MIPs (plenty fast enough for I/O)
Instruction Format
Assembler Input Format
CSV file with constrained input format. Header must match the example.
Compiler Input Format
First line WR001 compiles to:
Listing file:
