I got the IOP16 running and controlling the front panel.
It's currently looping back the pushbuttons to the LEDs. Here is the timing diagram for the I2C transfer (pair).
I2C Transfer - Read Pushbutton/Write LEDs
That's < 200 uS for read/write cycle.
Reads 4 banks, writes 4 banks in < 800 uS. Faster than 1 mS refresh rate. - better than the human eye. Good enough. 400 KHz transfers work at 3.3V (and 5V of course).
Created a branch in GitHub with the loopback working. If that's all you need, that will work. Push a button, turn on an LED. No debouncing of the pushbuttond, etc.
The firmware the IOP16 runs is FP01_LOOP1.
