The Live-A-Little e-ink display updates with a new "years remaining" prediction when the solar panel on the back of the device receives direct sunlight for at least 20 seconds. Suction cups to secure it to a window that sees direct sunlight at least once a day. The device will automatically update several times on sunny days and not at all on cloudy days.
If you are not particularly fond of the current prediction, pressing the button on the front of the display while will also update the display. Updating your current age simply requires using a jumper wire with the pins on the back of the device. Pin functions are "Set", "+", and "-".
The Live-A-Little device is fully solar powered and does not require batteries.
If you have access to a 3D printer and soldering iron, the total cost to build a Live-A-Little is less than $30.
John Opsahl
mircemk
Sritabh Priyadarshi
This has the same level of abstraction like personal dosimeter, but is way slower :D
