Used a cheap deep picture frame but my build was too bulky for keeping it under the frames plexiglass so it is open air and makes a quite nice cooling fan.
I also used a larger motor with a cheap pwm controller for varying speed.
Biggest problem is when testing under speed and having a crash, the glass magnetic switches break easy so have lots,,
Go to techlib.com under links select readers projects and then Karen's pages.
Or search "techlib" "Orrery" "Karen"
daw9000
G. Rosa
kd8edr
TK
ZenVega
