Overview
This project is to be a 3-part setup for teaching piano for beginners. It is intended to be a way to ease in people who have a desire to learn music, but are unsure if they are willing to fully invest. The original teaching modes are as follows:
- Piano Hero Mode
- Notes fall down in real time towards the keys
- In this proof of concept, the LED matrix doesn't span the width of the keys, but ideally that would be the case
- Chord Learning Mode
- The app would send a MIDI message that would end up being displayed on the LED Matrix
- Free Play Mode
- A piano connected to an RPI would be able to send the MIDI messages to the LED Matrix for display (similar to the Piano LED visualizers seen on YouTube)
The Free Play Modes and Chord Learning Modes are still in progress.
Currently, there is an Android App that sends MIDI files over Bluetooth to a Raspberry Pi. The Raspberry Pi then creates MIDI messages from the File to send as a set of 3 bytes to the Arduino for driving the LED matrix using the FastLED Library.
Components
- External Power Supply (For the LED Matrix)
- WS2812B Individually Addressable LEDs
- 1000 uF Bypass Capacitor
- Arduino Due
- Raspberry Pi 4
- Proper Cables (USB-C, USB-A, etc)
The components are quite expensive, but there are many clear places to reduce the overall cost. The Arduino Due can be changed to a much smaller board since its only job is to animate the LED matrix. The External Power Supply can reasonably be just 10A and 5V since the LEDs can be dimmed (they are annoyingly bright...). Finally, the LED Matrix just happened to be 44 keys which was why I purchased it (piano has 88 keys). It is much cheaper to create a custom LED matrix, though it may require much more engineering.
The Raspberry Pi seems quite useful for implementing all three functionalities at the end. All of these components are surely replaceable, but convenience should be a factor as well.
Process
Android Studio
Let's first discuss about the Android application. It was possible first to crudely design the application on an emulator, but Bluetooth required a physical device to even run.
**A workaround could be to use a VirtualBox or a VMPlayer to fully emulate the system and utilize your computer's Bluetooth.
This application consisted of several buttons and a navigation to another page (fragment). The second fragment consists of some default songs and a simple Bluetooth implementation.
One very important thing to do would be to move this socket connection and data transfer to another thread. A socket's "connect" method is blocking, and this would disrupt the QoL of the user.
private fun sendDataToDevice(msg: InputStream, device: BluetoothDevice){ try { val byteMsg = msg.readBytes() bSocket = device.createInsecureRfcommSocketToServiceRecord(appUID) bSocket.connect() var outStream = bSocket.outputStream outStream.write(byteMsg) Log.d("BT_SEND_SUCCESS", "Message was sent") outStream.close() } catch (e: IOException){ Log.e("BT_SEND_FAILURE", "Exception during write", e) } catch (e: NullPointerException){ Log.e("BT_SEND_FAILURE", "Null outputStream", e) } }
Nonetheless, the code suffices to transfer a default song to the Raspberry Pi.
Raspberry Pi
Configuring the Raspberry Pi for Bluetooth was quite a hassle. After installing pybluez (Python bluetooth library), the two most important insights to getting the Bluetooth working was the following:
- sudo hciconfig hci0 piscan
- This enables Bluetooth discoverability. Consider having this on startup.
- stack overflow
After retrieving the MIDI File, I modified the script to use the mido library from Python to construct a series of messages to send over UART to the Arduino using a baud rate of 9600. A bit of research was done at this point to play notes on the connected digital piano. In doing this research, I discovered that Linux has some interesting command line interfaces to work with the digital piano connected via USB. My piano had no drivers for...
