Specifications
- Two 32-bit MCU ,240MHz
- 520 KBytes SRAM
- 4M Bytes Flash memory
- there are 24 more GPIOs(only as output) with a expander, the communication speed is 1.4MHz, and the actual speed of gpio output is 70kHz jitter free stepping that can drive the X/Y axis to speed 900mm/s .
- WiFi | 802.11 b/g/n/d/e/i/k/r (802.11n up to 150 Mbps)
- Bluetooth | Bluetooth v4.2
- support 8 Motor drivers
- 3 heaters
- support 3 thermistors (30°C~250°C,can not read the value below 30°)
- BLtouch/ support wild range voltage 5V~36V Inductive sensor NPN.
- LCD128*64/PandaTouchScreen/DGUS touch screen(XH2.54 or RJ11)
- Support mixed use of 5V/24V fans,3 of them are controllabe fans
- Play music at boot, Error/alarm music..
- Real-time operating systems (RTOS)
- Control printer, upload files with web browser
mark
Made In workshop
Fiberpunk
E/S Pronk
