With the 8080 CPU in place I fleshed out the simulator with the various VT100 hardware components. I have previously added a few terminal emulators to Angelo Papenhoff's suite of vintage terminal emulators, so it was natural to use that as a starting point. I was able to quickly get the basic emulator up and running. The suite has support for rendering characters with a pleasant soft scanline appearance, which looks nice but is not really a good match for the VT100 video hardware. I hacked the code to stretch characters for double width and height text; if you look closely it's obvious the scaling isn't done properly.
