I have now finished printing all the pieces of the VT100 body.
It's now finally time to start gluing the pieces together!
As you can see, it's a bootstrapping process.
I think I managed to get the pieces aligned quite well. But this is only the raw material from which the final model will be furnished. I have lined up epoxy putty and filler primer to smooth out visible joint lines.
Lars Brinkhoff
Looks great Lars.
