OLED worked... at least once
A project log for ESP32 Small Alarm Clock
Small alarm clock with ESP32 module, 0.96" OLED panel and small speaker.
teruteru • 08/30/2021 at 12:00•0 Comments
This picture was taken at Aug. 7
I assembled updated PCB and it worked at least once. And it stoped working after I soldered optional LEDs.
I suspect too much heat damaged the panel.
But that is not a large problem as I have one working display and display is not critical for this alarm clock.
Anyway I finally implemented the speaker and electronics part is done. I did not make much progress to software part though, considering electronics part took more than 1 year to be done, I believe it will be reach somewhere in the future.
As for the speaker, I picked CES-26138-16L030 and CDS-25148-L100 for their sizes. Then I compared 2 speakers and felt that CES-26138 sounds better and used it.
By the way, I used this repository to test display.
