I pulled the fabric covered earpiece cable through the hole that the original cable came from.
![](https://cdn.hackaday.io/images/1236931625201342119.jpg)
A ziptie around the cable will prevent it from getting pulled out or straining any of the connections if th earpiece is dropped. I added a zip tie pad to prevent pushing the cable in to the phone from causing any issues with the rotating generator next next to where the hole is.
![](https://cdn.hackaday.io/images/3035121625201363326.jpg)
I printed the fake batteries and shells to make sure they fit. The shells screw on and will be covered by ~2mm of plastic.
![](https://cdn.hackaday.io/images/8360131625201393497.jpg)
