Its time to cut the base. If you look at the hand drawn designs you can see that lots of attention is spent on making the base/stamping mechanism. I need to mill pockets to accept the solenoids and solenoid plate.
![](https://cdn.hackaday.io/images/5802821623583040559.jpg)
The great thing about having a workbee is that its trivial to cut wood with reasonable accuracy.
![](https://cdn.hackaday.io/images/3941081623583095271.jpg)
As good as the CNC machine is, it doesn't make up for user error, or my inability to measure.
![](https://cdn.hackaday.io/images/8507831623583172024.png)
The pressing foot is fitting really well
