Normally I'd not bother with a logo, but as I've been given a Illustrator license through work, and the explosion in cheap heritage style clip art, means that its easier than ever for me to make a logo. Not only that, with the workbee its trivial to get that logo engraved in brass.
![](https://cdn.hackaday.io/images/7505801623604372409.jpg)
When engraving its really really important to make sure that your workbed is parallel to the spindle *and* that you've clamped your workpiece properly. As the depth of cut is <0.25mm it makes all the difference. TLDR: make sure you've surfaced your spoilerboard.
When I was designing the logo, I realised that the stock base that comes with the HÄRLIGA isn’t tall enough to house the solenoids. So I need to mill a base extension:
![](https://cdn.hackaday.io/images/2528371623604508902.jpg)
This is useful because I now have a form to hammer the logo plate into.
![](https://cdn.hackaday.io/images/259921623604562637.jpg)
Here is the finished logo in place.
Indian ink and acrylic gloss makes it much more believable:
![](https://cdn.hackaday.io/images/5896811623605179934.jpg)
