Main plate design
A project log for Stock Ticker Machine
An old style stock ticker machine for the modern world
secretbatcavesecretbatcave 06/13/2021 at 17:310 Comments
Its not overly obvious in the hand drawn design, but the main point of the main plate is as follows:
Because aluminium is expensive, I started prototyping in plywood, to make sure my assumptions were correct, and that it all fitted inside the jar
Even though I had the mechanical drawings of the motors, I hadn't allowed enough space to fit all the paper handling bits in.
The other mistake I had made was not accounting for the width of the metal plate that holds the solenoids. Having learnt from my mistakes, and making some tweaks, I finally milled the aluminium plate
You can see some scratches in the black gloss, note to self, always finish your aluminium properly.
Its starting to look really nice now.
Rich text editor
