2021 HACKADAY PRIZE CHALLENGE ONE: RETHINK DISPLAYS
In a situation where we need to rebuild our society, we are going to need a solution for low-power portable displays that can function in situations with limited power using renewable energy, durable enough to be protected from the elements, and in a form factor that is easily transportable. They will need to be intuitive and easy to use, and universal enough to be compatible with whatever devices we are able to scavenge.
Inspiration
This project was inspired by the COVID-19 pandemic and my childhood. When the pandemic first hit, many employers and employees in tech and other industries had to transition to working remotely, and experienced difficulties moving their multi screen setups home due to complex wiring and bulky monitors. Many businesses just decided to provide employees with a stipend to purchase new equipment for their home office to solve this problem. As an IT Director I understand how much a multi-monitor setup impacts productivity, so I sought out a better solution that could save companies money in case another disruptive event such as a pandemic forces employees to relocate their display setups. What I created ended up being so much more than a way to trim the budget, my creation gives the user the freedom to work wherever they please.
Growing up as a child with divorced parents with joint custody was challenging for me for many reasons, one of which was keeping track of what I had at each parent's house and what I had to pack. My parents couldn't afford to have two of everything so I often had to pack up what I needed for the week. Every single time no matter how hard I tried or double checked, I would forget something. This would happen so often that I started keeping everything I owned in specialized bags containing everything I needed for a specific occasion or activity. Every week I would go to the thrift store and search for bags, and one day I came across a briefcase. I purchased it to keep track of my homework when going between houses and pretty soon I started taking it with me everywhere. Naturally I started getting bullied at school for carrying it because it was considered "nerdy" (it was) and "old-fashioned" (I am). The bullying escalated to the point where my briefcase was being dumped out every day and was making it more difficult to function than it was worth so unfortunately, I had to go back to a traditional bag.
Years later at my first IT job after high school, I decided to break out the old briefcase to carry my tools around and instead of getting tormented, I got compliments. I started taking the case with me everywhere I went for my freelance jobs, putting stickers on it that I would get from gas stations along the way that would act as mementos that represented the adventures my work has taken me on. I still use the case to this very day, and decided to use it at the base for this project since it represented the challenges I have overcome in my life and the triumphs I have made in my career.
Specifics
My first prototype of the Solar Display Case consists of:
- Two 17 inch portable monitors with -
- Two on/off switches that control the USB-A to USB-C power cables leading from the monitors to the power bank to give the user more control over power usage. This is useful on cloudy days if the power bank is not recovering power as efficiently.
- A power bank that is also connected to -
- A solar panel on the exterior of the case to allow for charging even when the displays are not in use.
- The screens are mounted on two 12 inch industrial strength hinges so they can easily be folded and stored for transportation or environmental protection.
- The hinges are also spring loaded so the displays will move themselves to the fully extended position once the case is opened.
- The case itself is supported with two gas struts, which prevent the case from closing during use and help make the case easier to open.
The monitors can be removed from the hinges for standalone use or if a specific screen configuration is required, and the solar panel can be removed from the case to a position where there is more sunlight. This allows the user to work in the shade while still using the monitors to their full potential.
What's Next?
This build is for proof of concept.
- The final build will have solar panels mounted to the back of each display in addition to BOTH sides of the case, making the case completely solar.
- Other design goals are to add a third display (already done, but need to modify case mechanics for proper closure).
- A larger power bank is also being considered, however since weight is a factor of portability further analysis needs to be preformed to see if this is a worthwhile upgrade.
Usage
I designed the Solar Display Case so it is simple enough to be used by anyone anywhere by plugging in just one cable. Some specific fields where it would be useful include:
- 3D Modelers
- Developers
- Digital Artists
- Drone Pilots
- Graphic Designers
- Industrial Professions
- Law Enforcement
- Military
- Penetration Testers
- Photographers
- Preppers
- Researchers
- Scientists
- Video Editors
Want to code on top of a mountaintop? Done. Want to explore remote areas with your drone with an amazing field of view? You can. Want to screen share during your company meeting and be able to see the reactions of your co-workers while you create your amazing graphic design project in real time? Do it. The possibility and applications this project have are limitless. The Solar Display Case has removed a huge hinderance to productivity, and will change the way we work and communicate for the foreseeable future.
