As I already wrote at #Video Pendant, it's time to end this project. While I still think it should be possible to make animated GIF images displayed with this hardware, I simply don't have the energy to write the kind of optimized code that would be needed, and in the meantime there are much more powerful microcontrollers out there that can do it without a problem and as cheaply. So I'm shelving this.
I might revisit the idea in the future, but it will probably be with a different display and definitely with a different microcontroller.
