It's a two PCB stack with a mask between to protect from light leak. The map designs are put directly into the copper, PCB mask and traces on the pcb giving the project a unique look that is pretty affordable to build. It's WiFi connected so it can connect to my custom backend that shows the current location of each BART train.
