The Pi Pong project is not easy, and can even be overwhelming. It takes time and practice to wrap your head around the programming model of the Pi Pico's PIO, and it could be difficult to swallow this project in a single bite.
You can find here a step-by-step breakdown, which can guide you through the implementation of the project. It's totally optional - use it if you want, or just go on your own.
Step 1 - White Screen
Fill the screen with white color. At minimum, you'll need to drive the DATA signal high, and generate at least one Long Vertical pulse, followed by a series of Horizontal sync pulses.
And in pseudo code:
SYNC ← HIGH Repeat forever: SYNC ← LOW wait 30us SYNC ← HIGH wait 2us repeat 300 (or a similar number) times: SYNC ← LOW wait 4us SYNC ← HIGH wait 60us
I suggest coding the SYNC signal driving logic into a PIO machine, so you get precise timing.
Step 2 - Half white
It's time to take control of the DATA line too! Make it go HIGH about 6 microseconds after the end of the Horizontal Sync signal, then LOW again after ~22 microseconds.
You can start with controlling both DATA and SYNC using a single PIO machine, and then move on to controlling them with two distinct machines that synchronize using the IRQ and WAIT instructions.
Pseudo code:
DATA ← LOW
SYNC ← HIGH
Repeat forever:
SYNC ← LOW
wait 30us
SYNC ← HIGH
wait 2us
SYNC ← LOW
wait 4us
SYNC ← HIGH
wait 10us
DATA ← HIGH
wait 22us
DATA ← LOW
wait 28us
Step 3 - Frame buffer
Instead of hard-coding the data line to stay HIGH for the first half of each line, we'll let the program feed the data. I suggest starting with 32 bits (pixels) per line (not so great resolution, but still usable), then going up to 128 or even 256 bits.
The idea is to have two PIO machines: one will drive the SYNC signal, and the second one will pull the data from the program one 32-bit word at a time, and then drive it to the DATA signal. Using the "Autopull" PIO setting is highly recommended!
Your program will start both PIO machines, then feed the data to the Data machine. I suggest creating a buffer with the screen contents (frame buffer), and then repeatedly copy data from this buffer into the TX FIFO of the DATA-driving PIO machine. You can feed the data using an interrupt handler (either TXNFULL interrupt/IRQ triggered explicitly by the PIO machine code).
Note: I recommend using C++ (Arduino core) for the game. But if you do use MicroPython, define your interrupt handler as a hardware interrupt (pass "hard=true" when defining the handler). Note that there are some limitations for what you can do inside an interrupt handler: for instance, memory allocation isn't allowed.
Note 2: Ideally, you can use the DMA controller to automatically feed data from memory into your Data machine. DMA is currently not supported in the emulator, but this will probably change in a few weeks. Until then, you can try the DMA approach with a physical Pi Pico and PAL TV (or logic analyzer).
Sync machine pseudo code:
SYNC ← HIGH
Repeat forever:
SYNC ← LOW
wait 30us
SYNC ← HIGH
wait 2us
SYNC ← LOW
wait 4us
SYNC ← HIGH
Trigger IRQ (to notify the Data machine)
wait 60us
Data machine pseudo code:
Repeat forever: DATA ← LOW Optionally trigger an IRQ to notify the code we're ready for more data Wait for an IRQ from the Sync machine PULL 32-bit word from the TX FIFO Shift the one bit at a time through the DATA pins
Step 4 (optional) - Perfection
At this stage, the PAL TV driver should be ready for you to use in your code! All you have to do is to write the pixel data to the framebuffer, and the PIO machines will take care of generating the right signal.
However, the SYNC signal is not perfect yet. It's working in the simulator and is good enough for this assignment. But if you want to get it perfect (perhaps you want to try it with a real TV), you are definitely invited to do so! I included here some pseudo code to help with that:
SYNC ← HIGH
Repeat forever:
If odd frame:
Repeat shortSync() six times
Repeat longSync() five times
Repeat shortSync() five times
Else (even frame):
Repeat shortSync() four times
Repeat horizontalSync() 305 times
shortSync():
SYNC ← LOW
wait 2us
SYNC ← HIGH
wait 30us
longSync():
SYNC ← LOW
wait 30us
SYNC ← HIGH
wait 2us
horizontalSync():
SYNC ← LOW
wait 4us
SYNC ← HIGH
wait 60us
Note: it can be challenging to pack all this functionality into the 32 instruction space of the PIO machine, especially when you also have the Data machine that should fit into the same space. But it's possible - I managed to encode the Sync machine with just 20 PIO instructions.
Step 5 - Pong
Now, with the framebuffer at your disposal - you are ready to write the actual game. Good luck!
Uri Shaked
