- Variant 1 - The "Super Easy"
- This is what I started with. I used a borrowed black photography backdrop and a large selection of big binder clips. (2" - 3" Large ones worked best)
- This only works because I had a low ceiling with drop in tiles.
- Hold one side of the backdrop up, then clip it in place. Starting by clipping both corners while holding the middle seemed to work best. Otherwise the weight will cause it to slip out.
- Problems
- Difficult to put up
- No easy was to relocate it
- Requires the right ceiling (Drop in tiles with rails)
- There was always a chance of backing into it/ bumping it and causing a dramatic reveal.
- I was worried the clips might damage the backdrop fabric over time
- The single layer backdrop didn't fully block light from the window behind it.
