The delivery from JLCPCB arrived yesterday (2022-11-23). I did an unboxing video where I soldered up one example, did a smoke test, programmed the two processors and showed we get VGA video output.
Check it out!
A project log for Neotron Pico
A microATX motherboard that uses a Raspberry Pi Pico as the CPU. SuperVGA output, stereo audio, a BIOS written in Rust and not much RAM!
Check it out!
