I measured the casing to the length of the LED strips leaving extra room on either side so the solder joints will be protected.
Once the casing is cut to size and the LED strips are slip through I soldered the ends together making sure the arrows direction on the strips were both pointing in the same direction and the wires were in the correct order. I also soldered the wires at different lengths to be able to have the correct angle.
