There was space between the end of the boot and my heel and it was the perfect holding spot for the board.
I used double sided tape and foam tape to attach the LED strip...It stuck to the boot fine but kept falling off the silicone casing. So I glued the double sided foam to the casing using silicone caulk and then attached it to the boot
Robyn W
