Current Features:
- Record's video
- Can stream video to outside source like Twitch
- Can switch between being a WIFI client device and acting as a AP Host to connect to the pi directly
- PI can server a web UI to interact with the device and edit various settings
- Realtime camera preview
Planned TODO:
- Add audio to recordings and streams
- Save recordings to separate partition on SD Card to make pulling videos off easier
- 1 command install and setup script and/or prebuilt image
- Improved configuration
Current Bugs/ Issues:
- The Pi seems to somehow get it's DNS system messed up at some point breaking basically everything (like apt and streaming) that require DNS resolution to work
- Audio from the is2 microphone does not work with the current FFMPEG setup
TurkeyDev
Warren
lelex76
Daniel
Looking at making something like this but need it to be waterproof, do you know any cases or enclosures that would work with a Pi Zero
